Changes in sheet metal flange tool
GC_CC
GC_CC
I make this sketch for a simple U-shape bended sheet metal plate:
Sketch is made with a centerline and is fully defined.
Next I try to add material to it using the flange tool.
It now treats this sketch as 2 seperate profiles, which it did not use to do. It used to make it 1 profile by connecting the 2.
Switching the Orientation from side 1 to 2 flips both profiles, so it creates a part which cannot be properly unfolded.
Something has changed in the way the flange tool behaves.
This post goes about the same problem probably: https://forums.autodesk.com/t5/fusion-design-validate-document/sheet-metal-flange-tool-weird-new-beh...
Any suggestions on how to fix this or can this be looked into?
kacper.suchomski
Hi
Yes, this is strange behavior. There's probably some bug in the algorithm recently.
To prevent this behavior, simply avoid creating an unnecessary center line.
I hope @johnsonshiue passes this error on to the development team; at the same time, it's important to remember that sketches should contain as little geometry and information as possible; and doing this from a clean sketch gives the desired effect.
Kacper Suchomski
johnsonshiue
Hi! It was reported as FUS-216273. The current status shows that it has not yet been resolved. Please feel free to contact Autodesk Product Support and escalate it.
Many thanks!
Software Test Engineer
