Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Sheet Metal designing 45 degree corner joins
2 REPLIES 2
633 Views, 2 Replies
Hi just after some advice on the best way to design 2 separate sheet metal components to be welded together.
In the file i have a large vertical flanged  side  and the smaller flanged top I want to bring together on the long edge to weld. So in the right view I am looking to say cut the flanges at a 45 angle so they can but together and be welded.
Is this possible to be modeled correctly so it is incorporated into the flat pattern?
2 REPLIES 2
TheCADWhisperer
I am having great trouble visualizing what you need.
The attached image is a bit if a fudge to try to figure out your Design Intent.
in reply to: TheCADWhisperer
That is the finish I am trying to achieve if the top section is a separate body?
I have update my file and moved the top section over to the side panel where i would be welding it.
The flanges that are now on top of one another (on the Right side view) I cant find a solution on how to cut them on a 45 deg angle to achieve a push together fit.
