Sharing projects issue
adamw.14128
adamw.14128
When I share a project via email to view in browser it displays all bodies and faces in the project regardless if i set them to invisible. This is rather annoying since the objects I've set to invisible should be kept invisible. Is their away to save all appearance based settings when sharing a project.
Or maybe hiding hiding my sacrificial cutter objects/surfaces incorrectly idk..
SaeedHamza
If you hide bodies or faces and they still appear in the shared model, I suggest turning on the timeline and using the Remove command from the browser.
That way they can't possibly appear in the shared model, and you can always delete the Remove command from the timeline to restore the "deleted" parts.
You can think of it as hiding them, but using the timeline instead of the browser
Saeed Hamza
