selecting axis Y to move axis Z
matthew
Message 1 of 21
matthew
I have noticed that in order to move a given part in the Z axis, I must select the Y axis in the move function.  Can someone explain why this is?  I have attached two screen shots, the first is a measurement of the Z axis, the second is the Z axis being moved using the Y Distance field of the Move function.
Matthew Hertel
Replies (20)
Message 21 of 21
HughesTooling
I'm not too worried about this but it does seem a bit odd, what I find is if you pick a face Y on the move dialog always points away from the face you've selected.
But if you select the body or component from the browser the move dialog Z matches the component origin.
Selected component from browser.
Component rotated 90° then selected for move and Z is along the component Z.
Mark
Mark Hughes
Owner, Hughes Tooling
