selecting axis Y to move axis Z
matthew
Message 1 of 21
matthew
I have noticed that in order to move a given part in the Z axis, I must select the Y axis in the move function.  Can someone explain why this is?  I have attached two screen shots, the first is a measurement of the Z axis, the second is the Z axis being moved using the Y Distance field of the Move function.
Matthew Hertel
Replies (20)
Message 2 of 21
daniel_lyall
its in the setting you can have y as up or z as up
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 21
matthew
Can you point out where in the settings this is?
Message 4 of 21
daniel_lyall
did a screen cast http://autode.sk/17OGGOT
Daniel Lyall
The Big Boss
Mach3 User
Message 5 of 21
matthew
Thanks Daniel!
I think that the feature must be broken on the Mac version of Fusion b/c that did not seem to work.  Do you know where I should post the broken feature?
https://screencast.autodesk.com/Embed/Timeline/5032805f-4ba8-4e7f-b8aa-fedce2f1fe4c
Matthew Hertel
Message 6 of 21
daniel_lyall
it may need a restart try that if it still broke start a new thread about it with your vid
Daniel Lyall
The Big Boss
Mach3 User
Message 7 of 21
I have the same problem with windows, Blue-Z axis shows up in the Y distance box.
Todd
Message 8 of 21
daniel_lyall
that becouse Y is up it all covered in the manuals some where and past posts
Edited by
Discussion_Admin
Daniel Lyall
The Big Boss
Mach3 User
Message 9 of 21
@daniel_lyall wrote:
that becouse Y is up it all covered in the manuals some where and past posts so rtfm LOL
It is moving in the BLUE axis, which is Z, and showing the movement in the Y Distance box.  I never mentioned the direction "UP".
Todd
Message 10 of 21
daniel_lyall
what direction is it pointing have change from y up to z up
Daniel Lyall
The Big Boss
Mach3 User
Message 11 of 21
daniel_lyall
i did a screen cast showing whats what and how to get z as up
http://autode.sk/1vDANcb
Daniel Lyall
The Big Boss
Mach3 User
Message 12 of 21
Up has NOTHING to do with it.  Up is relative and can be changed to the viewers needs, and has nothing to do with this discussion.
Blue=Z, it's set, there is no changing it.
That being said,
A movement on the Blue,Z axis  is being displayed in the Y Distance box.
Message 13 of 21
daniel_lyall
it can only show movement in its realitve coradantion in the screen cast i did it moved from where it was in the direction it was orientated it was set to y up  but up direction was x then i flipted it, so a move in a up direction was Z axis left to right was x back to fount was y. rule of thum
so you can have it move how ever you wont they may fix it one day so the move orientation is the same as the colours for the triad.
thats the point the colour orintation and the move orintation does not match so you have to work around it
its a pain I know, I redo the orintation to how I like it when I start a new drawing, also it makes fac all of a diffrences when it comes to the cad side becouse you can set that to how you wont
Daniel Lyall
The Big Boss
Mach3 User
Message 14 of 21
daniel_lyall
have a look at this its half the problem
http://forums.autodesk.com/t5/sketching-sculpting-modeling-and/move-axis-is-incorrect/td-p/5502392
Daniel Lyall
The Big Boss
Mach3 User
Message 15 of 21
No matter how many different ways it's being justified, it's still wrong.
Todd
Message 16 of 21
daniel_lyall
yes it is I hope its fix so I don't have to manually redo it every time I do something
Daniel Lyall
The Big Boss
Mach3 User
Message 17 of 21
innovatenate
Autodesk Support
Autodesk Support
Thank you for the feedback. I have to agree that there does seems to be room for improvement here.
I've created a report for development to investigate this issue further (Reference ID FUS-16649).
I will circle back here with any updates.
Nathan Chandler
Principal Specialist
Message 18 of 21
Has there been resolution on this?  I just got it and it's driving me crazy.
Message 19 of 21
innovatenate
Autodesk Support
Autodesk Support
Thank you for the nudge.
Currently, the default position of the triad is based component instance coordinate system. For example, If the component instance was rotated about the Z-axis by 900, then triad would be placed as below.
Else the triad X,Y,Z would align with the world XYZ. If you use the re-orient functionality to orient the triad axis, then you may get the triad to align with the world coordinate system.
Does this help?
Nathan Chandler
Message 20 of 21
Anybody? Was this fixed? I am still seeing this.
Move functionality is unusable.
