3d print dialog - what's the value?
Hey guys,
I'm trying to figure out why I should use the 3d print dialog.
If I use the 3d print dialog, it dumps the STL into Meshmixer, which then dumps it into MakerBot software for slicing.
If I use STL export, it dumps it into MakerBot software for slicing.
It seems like STL export is more efficient and has less data transfer between programs.
Am I missing something? Can I slice right from Meshmixer?
Would be super sweet to orient and slice from Fusion. The closer you guys can get to a "Print" dialog the better... how many CAD programs have a "3d print" dialog that just... prints? 🙂
Played around with it a little, 3d print dialog lets you go right to MakerBot software which is pretty slick... 🙂
Would be cool to punch in allowances or corrections... for example, this 3d printer always does ID/OD on the XY plane 0.50mm under/over and it would be neat if Fusion could do corrections before going to slicer... some slicing software doesn't have a lot of control over this stuff. 🙂
gautham_kattethota
Hi Luke,
WIth regards to your comment on allowances/corrections, are you referring to corrections made on the model to account for shrinkages on a printed part?
Gautham
Gautham Kattethota
Software Development
Shrinkages or just poor machine setup.
With my home printer I am able to tune it, but with the one at school I am not, so I have to get creative with offset faces to get things to print true to size! 🙂
