Scaling a made part but...
killbillvol13
killbillvol13
Hey, I want to scale a part I made. I made a cube, put a hole through it and did the scale command and checked dimensions and it was scaled to my test. Ok.
What would be the best way to scale a part but keep some of the dimensions? If possible. Example, a half circle ribbon that is 20cm x 2.54cm x .6cm and has several holes and slots that are .65cm. I want to make a smaller size ribbon but keep some dimensions the same. So, scale it to 80% of the size but maintain the width, thickness, and holes and slots the same size. Is it even possible? Or do I have to re-sketch the size?
If I cant, then I was thinking of copying the sketch before I start a sweep command and scale it to my desire. Then add in the slots and holes.
jeff_strater
The way to do that is probably via the timeline.  If you have the scale operation at a place in your timeline where the parts of the design you want to scale have been created, and then you create the holes and slots afterward, they will not be affected if the scale changes.  Alternatively, create your entire design (sketches, extrudes, etc) to be based off a user parameter called "scale".  that is a lot more work, but can also be effective in creating differently sized results
Jeff Strater
Engineering Director
sunil.patilQCZZK
Hi @killbillvol13 ,
Scaling will change the size of the part completely which are in timeline for instance in your case width thickness and slots. Here are some approaches to achieve the same .
  1. Assuming the modeling is done in Fusion 360 with timeline turned on. You can go back to timeline which suppresses slots and  other dimensions and try to scale (Completely depends on the approach you modeled).
  2. Use Pull command to control the length.
The solution is given by your explanation of problem. It would easy to suggest, if you share the file and some screenshot.
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! "Like" is always welcomed.
Sunil Patil,
Technical support specialist Fusion360,
Autodesk, Inc.
killbillvol13
Thank you guys, I will try this out when I get a chance. I have to redesign the part so it is going to take me a bit. The part in question has to be redesigned and I decide to remake it entirely. After that, I will try your suggestions on the new design. This blows but oh well. Appreciate it.
