Editing a Mesh
Editing a Mesh
nt4598
Editing a Mesh
nt4598
I have imported a model of a Racing Sparrow RC yatch as a mesh, i plan to hollow this model out and then split, make some alterations to the hull.
Is there are guidance on how to remove the deck to hollow out the hull? Any there any links to where i can read up on how do interact with meshes?
hamid.sh.
Fusion is not a mesh editing software. There are only a limited number of things you can do with a mesh in Fusion. You might be able to separate the deck (by painstakingly making a face group out of it in Direct Edit mode and then using Separate), but still I don't think you ultimately get what you need.
Hamid
wersy
Don't waste your time working with a mesh.
Just download a solid from grabcad.
https://grabcad.com/library/racing-sparrow-750-1
