Scaling a made part but...
Hey, I want to scale a part I made. I made a cube, put a hole through it and did the scale command and checked dimensions and it was scaled to my test. Ok.
What would be the best way to scale a part but keep some of the dimensions? If possible. Example, a half circle ribbon that is 20cm x 2.54cm x .6cm and has several holes and slots that are .65cm. I want to make a smaller size ribbon but keep some dimensions the same. So, scale it to 80% of the size but maintain the width, thickness, and holes and slots the same size. Is it even possible? Or do I have to re-sketch the size?
If I cant, then I was thinking of copying the sketch before I start a sweep command and scale it to my desire. Then add in the slots and holes.
