Same depth cut on uneven surface
bigmaubis
Observer Observer
bigmaubis
Observer
Observer
Hey guys, I’m wondering how I would go about cutting a profile down into an uneven surface of a solid but for it to be the same depth from the surfaces?
I want this profile to be cut into the part 8mm from the different surfaces uniformly
davebYYPCU
Surface > Create Offset, Set Offset At 8 mm, selecting all those top faces
Extrude to Object, Select Surface Body in the Browser.
Might help.....
laughingcreek
you can do it with "extrude to", setting the offset to the depth you want-
FYI-both windows and macs come with screen clipping software preinstalled which will result in better pics to attach than using your phone.
