Stiffening Ribs In Sheet Metal
kevinwatts
Message 1 of 10
kevinwatts
Has anyone found a way in the Sheet Metal Workspace to add embossed ribs on the inside of bends to act as stiffening ribs for sheet metal parts?
Replies (9)
Message 2 of 10
stiller.design
there is no direct way, but you can always cut out some sections and model some stiffening ribs with surfaces and then thicken them. Not a straight forward way but possible
Message 3 of 10
etfrench
How would you make them in the real world?
ETFrench
Message 4 of 10
TheCADWhisperer
Relatively easy to model if you don’t need Flat Pattern.
But these are deformation process and Fusion is (mostly) limited to cylindrical or conical bends.
Message 5 of 10
kevinwatts
Yes, I agree. It would be easy to model if not in Sheet Metal Workspace or in Sheet Metal Workspace if you don’t need Flat Pattern.  If it was a short run you could just weld a plate against both inner surfaces. For mass production it would be better to punch the feature and bend as needed.
Message 6 of 10
TheCADWhisperer
Message 7 of 10
alexandwirtz
how is this modeled in fusion? can you provide the file or explain the steps taken?
Thank you!
Alex
Message 8 of 10
TheCADWhisperer
@alexandwirtz
Can you File>Export your *.f3d file of your attempt to your local drive and then Attach it here to a Reply?
While the geometry can be modeled - do you understand from the discussion that Fusion will not create a Flat Pattern with the rib.
Message 9 of 10
alexandwirtz
Thanks for your response, I figured out a way to model it (see attached). -The flat pattern I is not necessary in this case, but its possible to just export it before the "stamping" of the model or while those features are suppressed.
Thanks!
Message 10 of 10
TheCADWhisperer
@alexandwirtz
You have numerous unresolved issues highlighted in your Timeline, therefore I will have to start over from scratch to demonstrate how I would do the model. (There is an easier technique.)
I have some other designs ahead of this one - so check back.
