I have tried to do some research through google and on the forum for this, but I cannot seem to figure out how to do what I want to do. First, due to the nature of the part, and its complexity, there is no way to sketch fillets and sweep the part to get rounded fillet corners. Second, *ideally* it would be nice if the fillets flowed into one another.
The example I have posted below is a quick mock up of the part just so you can see basically the issue. Instead of having a sharp edge at the meeting of the two fillets, I would like a rounded edge.
Solved by HughesTooling. Go to Solution.
@M>oolWorks wrote:First, due to the nature of the part, and its complexity, there is no way to sketch fillets and sweep the part to get rounded fillet corners.
No way? There are a bunch of ways to tackle the shape- I can imagine one employing Sweep. Or Loft. Or Press Pull and a sphere.
What's stopping you? Just add a Fillet to the edge where they meet. Of course, if you want the corner rounded, the Edge that feeds into the corner will be rounded.
@M>oolWorks wrote:Fusion does not allow me to select the edge.... hence the question!
That is inexplicable. If you will record a screencast of your workflow, that might be a great help. It's a free Autodesk product- find it here:
https://knowledge.autodesk.com/community/screencast
It doesn't seem inexplicable, looking at your picture you were not able to select the edge either?
Made up the video you requested:
@M>oolWorks wrote:It doesn't seem inexplicable, looking at your picture you were not able to select the edge either?
Thanks for the video. You selected the Edge repeatedly in your demonstration- it highlights in blue and a control arrow is attached to it; you'll then have to enter a value or manually modify the arrow position to produce a Fillet. The image I included above includes a Fillet applied to one of what I understand to be the subject Edges.
Not once was I able to select the edge, hence the repeated attempts.
Please, do not respond any further, it is obvious you do not wish to help, or you would rather play some esoteric game of semantics that I neither wish to, nor have time to, play with you.
If anyone else is either able to speak in a manner that is helpful, or give actual input in regards to the question, that would be much appreciated.
Your presumption of ill will is ill considered and unjustified, Nathaniel. You'll find more often than not differences in perception are the culprit. I've amended the above post with additional illustrations to help bridge that gap. I understand your frustration- but lament the incivility. We all fall down, sometimes- no big deal.
-Christopher
...and a Screencast of your Screencast to make the selection unmistakably, explicitly clear:
I think @M>oolWorks wants to maintain a sharp corner for the vertical edge and just blend the 2 fillets. I'm not sure what that would look like or is even possible, if you add a small 0.0001 rad to the vertical edge you can get this but you only get an option for a setback fillet.
Mark
Mark Hughes
Owner, Hughes Tooling
@HughesTooling wrote:I'm not sure what that would look like or is even possible, if you add a small 0.0001 rad to the vertical edge you can get this but you only get an option for a setback fillet.
Very nice, Mark; your results resemble what might be had with a Replace Face. I had to work the Fillet on both sides of the Body to get your results. Hey, what characterizes a "setback fillet", anyway? -what distinguishes it from a Rolling Ball?
Another way to tackle it without the slight edge rounding would be to select the second small Line segment from the top of the Fillet and apply a Variable Fillet- shown here going from zero to .029 at the top:
@mavigogun See attached file. You need to do all fillets in one feature to generate a setback fillet on corners with more than 2 fillets meeting.
The file has 3 components. One how to blend and keep a sharp vertical corner with equal fillet rads, just did this one as a practice. Second one used unequal rads, looks pretty ugly. last version is using a fillet set filleting all edges in one go.
Mark
Mark Hughes
Thanks, Mark- I just fumbled my way through the operation a few minutes ago, now reading your post! Still, if you hadn't shown it was possible, I wouldn't have tried. Examining your new examples now. Thanks again!
@HughesTooling, Mark, as you illustrate, Fillet order can yield radically different results. Check out this image, in which the Edge of the Red Faces have been drawn across the concave Blue Fillet and over the Convex Green Fillet. Wild, huh?
Adding a .01mm fillet to the front edge while creating all 3 gives me the result I want. Thank you.
@mavigogun Setback fillets have 2 uses I think. One to allow patching\filleting a corner where 3 or edges come together especially with different rads and second just for appearance.
There quite a good thread here on the Rhino forum discussing filleting edges on high quality consumer produces where simple G1 fillets are not good enough. Pascals' first couple of answers explain quite well. Here's another thread worth a look on multi blend corners.
Mark
Mark Hughes
