Revolute Joint: direction clockwise/counterclockwise
lieve.w
lieve.w
How can i change the direction of the revolute joint in Fusion? e.g. from clockwise to counterclockwise. i can't find it...
TheCADWhisperer
@lieve.w
Are you using a Motion Link?
lieve.w
I only use one Revolute Joint with a Rigid Group of three pins that rotates together in a ring.
How can I change the direction of the joint?
TheCADWhisperer
@lieve.w
lieve.w
Here is my .f3d file
jhackney1972
There is no command or setting to reverse a Revolve Joint, you just have to trick it into reversing.  You will find the process outlined in this YouTube video.  Your reverse rotating model is attached.  By the way, your posted model was rotation in a counter-clockwise rotation.
If this answers your question, please select the "Accept Solution" icon on my post. If you have further questions, please ask.
John Hackney, Retired
