Weird threading artifact
andy_woodward66
andy_woodward66
I created a round bar 5mm dia. x 37mm. I then applied a 5 x 0.5 thread along 17.5mm of the rod's length.
The diameter of the clean end has now changed to 4.927mm.
Why would it do that???
TheCADWhisperer
@andy_woodward66
Because of the root/crest diameters of the thread specification.
Split your face to avoid.
andy_woodward66
Yeah, I figured out the crest dimension - but why apply it to the rest of the part? You're literally telling Fusion not to do that.
IRL, if you tap a piece of round bar in the same way, the rest of the bar doesn't magically change dimension. FFS.
laughingcreek
true, but you would also foul and shorten the life of your die feeding in over sized stock.  IRL you would put a shoulder on it.  that shoulder needs to be defined in some way, otherwise fusion would have to guess at it, and that would be the complaint instead.
MRWakefield
I'm not sure I would necessarily agree with this. M5x0.5 6g has major dia. tolerance limits of Ø4.874-Ø4.98 so at the most you'd be turning off 0.126mm (0.063mm radial) before screwcutting or running a die down it. In practice you just wouldn't, as you'd let the screwcutting tool or die 'top' the thread. This has been normal practice in the companies I've worked at for the past 40+ years. You may do things differently but that's my experience.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
andy_woodward66
But you wouldn't shoulder the entire length of the stock either -  only for the length of the thread.
So why over-model it in the software when the user will assume that the thread dimensions will only be applied to the designated thread.
andy_woodward66
I'm not a machining expert, but thank you for explaining it in real terms.
I suspect the issue is another Fusion bug being explained away as a 'feature'.
