Moldflow Icon in Ribbon
bwalker145
bwalker145
Is there a way to remove the MoldFlow icon from my toolbar?
Between Automate, Configure, and now MoldFlow, I'm losing a lot of real-estate to icons that have minimal or no use in my workflow. If there's a way to at least drop these into an existing container, that'd be great.
sanjay_jayabal
Hi bwalker145,
Can you try clicking the Moldflow button and while holding it clicked, drag it off the toolbar?
Best Regards,
Sanjay Jayabal.
HughesTooling
I guess this is an add in? Can you disable it if you go to the utilities tab then add ins, then stop it and uncheck Run on Startup?
Mark Hughes
Owner, Hughes Tooling
bwalker145
@sanjay_jayabal
Click-and-drag doesn't work, I also don't have the option to un-pin from toolbar.
Don't see any options within MoldFlow either.
bwalker145
@HughesTooling
Looks like that was it, thanks!
