RESOLVED - Fusion 360 service degradation (can't get online?)
brianrepp
Community Manager Community Manager
Message 1 of 54
brianrepp
All – we are currently experiencing intermittent service issues that may impact your ability to login and/or return from being taken into offline mode.  The issue may also affect your ability to run a cloud solve Simulation.  We are actively working on repairing the problem and appreciate your patience (NOTE - we have an update planned for the evening of 10/13/16 that should fix the issue).
Below is a workaround that should allow you to return online and/or complete a cloud solve, please let me know if you have any trouble.  In order for the cloud solve to re-initiate, please make an change to the affected document after removing the XML file.
Remove the LoginState.xml file and Restart Fusion 360:
Mac OS
  1. Close Fusion 360
  2. In Terminal, type the below command and press enter
    open ~/library/
  3. In the Subsequent Finder window (Macintosh HD > Users > %Profile% > Library), browse to
    ~/Library/Application Support/Autodesk/Web Services
    NOTE - if you are on a version from the Mac App Store, browse to:  ~/Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application Support/Autodesk
  4. In the Web Services (or Autodesk for App Store) Directory, locate the LoginState.xml file
  5. Right click on LoginState.xml and select Move to Trash
  6. Restart Fusion 360
Windows
  1. Close Fusion 360
  2. In windows explorer browse to   %localappdata%\autodesk\web services
  3. In the Web Services directory, right lick on the LoginState.xml file and select delete
  4. Restart Fusion 360
Replies (53)
Message 21 of 54
brianrepp
UPDATE - Data uploads and imports are back to normal and you should not be seeing any delays. The original issue of the inability to login/return from offline may still exist for some users, and if so, please follow the suggested workaround below.
Message 22 of 54
Confirmation that workaround resolves issue at 10:00 AM CST 10/12/2016.
Message 23 of 54
Zero__
I managed to get out of Offline mode by closing Fusion 360 and deleting the loginstate file found here:  ~/Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application Support/Autodesk.
Would you please update your original post letting people know that if they downloaded the file from the App store the path to LoginState.xml is different? Took me some confusion and digging through the thread to figure out why I couldn't find the file.
"The future is already here - it's just not that evenly distributed."
Message 24 of 54
brianrepp
Hey @Zero__ good to hear!  The instructions for App store versions are in the original post, but i'll highlight them to help it stand out a bit more.
Message 25 of 54
Zero__
Must've missed em, thanks!
Message 26 of 54
21652157
Hi Brian, It is for this problem I can´t see any render and renderized motion study? The cloud doesný work in my Fusion
Message 27 of 54
JBerns
Fusion 360 was offline yesterday morning and it appears to be offline again this morning, Thursday, Oct 13.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 28 of 54
21652157
Thanks you Jerry Smiley Happy
Regards
Gilberto
Message 29 of 54
brianrepp
@21652157 - were you able to access the rest of your data within Fusion 360, but only the render was not working?
Message 30 of 54
JBerns
Brian,
I was only able to access a few offline models. I did not try using Render. It appears that cloud service has been restored at this time.
Jerry
CAD Administrator
Message 31 of 54
21652157
Hi Brian
Render didnt  work this morning. I can do it now.
Thanks you
Regards
Gilberto
Message 32 of 54
brianrepp
Thanks @21652157 and @JBerns - it does appear we had some short isolated issues in the early morning hours, which likely caused what you were seeing.
Message 33 of 54
Zero__
Having the same offline problem as I had yesterday. There's no LoginState.xml file for me to delete anymore. What do I do?
Message 34 of 54
charegb
That seems unusual. Were you prompted to login when you started Fusion?
Can you send your logs to us for further investigation? Can be found under the Help menu->Diagnostic Log Files.
Bankim
Message 35 of 54
brianrepp
All - this issue which prevented some users returning online after being taken offline has been fixed with this evenings update.  Please let me know if you are still experiencing this issue!
Message 36 of 54
Hello Brian and others
my Fusion updated today to the current version 2.0.2455 and I am forced to offline mode. I already did your solution and deleted the LoginState.xml file but this isnt working.
Message 37 of 54
brianrepp
Hey Fabian - I received your email and log files. We will take a look at what's going on and respond soon.
Message 38 of 54
Mike.Grau
Hi @Anonymous,
Thank you for sharing the log files.
As we could see the issue might be related to Network connectivity / Proxy settings.
Please, keep us update if any of the suggestions helped.
Message 39 of 54
Hello Mike and Brian
it seems to be an issue while changing my email address. After changing the email address on https://accounts.autodesk.com/ back to my previous email it is working fine.
Seems to be impossible to change the email (credential) information for Fusion 360.
It would be nice to use more than one email, or at least an alternative email, for an account like it is possible on Github. This would be much better to invite others.
Thanks for your help!
Greetings Fabi
Message 40 of 54
I'm still not able to get back to working online.
Windows 10, Fusion worked fine till last week.
Edit//: Working fine now. Haven't changed anything.
