Resizing difference inkscape svg
10 REPLIES 10
Message 1 of 11
3305 Views, 10 Replies
I create a simple pattern in Inkscape with outside dimensions of 4.5 inches square.
In Fusion my resulting model is 1.185 inches square.
Why are the svg elements being shrunk?
Tags (2)
10 REPLIES 10
Message 2 of 11
I've learned that you have to resize the svg elements back to normal size because Fusion shrinks everything....
Tags (2)
Message 3 of 11
SaeedHamza
Could you please attach the file you imported
Regards
Saeed
Message 4 of 11
in reply to: SaeedHamza
see attached
also see jbox2.png above - it has the dimensions shown in the svg....
Tags (2)
Message 5 of 11
After running into a similar problem, here's my version of solving the problem and it works with a few caveats.
1. You should using Windows 10 and Inkscape 0.92 (or beyond), such that the default 'resolution' is 96dpi. I don't know where this comes from, but the 96dpi factor kept popping up in all tests I ran (probably Inkscape is the culprit)
2. In Inkscape, change the document properties (bring it up by pressing Ctrl+D while the document is in focus) to the following:
->Display Units: in
->Custom Size Units: in
->Scale x: 96.000
3. Now create your inkscape sketch (e.g. creating a box which is 100mm x 100mm) by setting units and dimensions as the real dimensions needed.
4. Save file and then import it into Fusion.
The attached file has two square paths (1x1in and 100mmx100mm)
The imported dimensions are 1x1in and 100mmx100mm
Message 6 of 11
MarcoCas
Hi.
I have found this 3d and I have the same problem.
But I use mm instead of in.
Into document property, with Inkscape 0,91 and fusion 2.0.511  on MAC I have set
Display units: mm
Resize, Scale x: 0,37795
Now when I import it's all ok.
Marco Casalegno - Fusion 360 on IMac i7 2012 - Zortrax Inkspire
Message 7 of 11
Nickduino
in reply to: MarcoCas
I'm encountering the same issue with a scaling factor of about 4.
I didn't find the DPI setting in the page setup of my Inkscape v1.1
Message 8 of 11
raycon2010
in reply to: Nickduino
Same here. Scale is off by 3.78(rounding to 2 decimal places)
I took a look at the InkScape generated SVG file  in a text editor .  The style attribute for my first rectangle element in the SVG file has a stroke width of 0.26458332  the inverse of  which is 3.7795.
Guessing at it. I'd say fusion grabbed the stroke-width attribute and made that the scale factor (for all my future SVG imports as well?).  Or Fusion has a static scale factor of 3.78 hard coded.
The way I use SVG's I'd import the file "unfix" throw in a dimension and then scale off that.
SVG snippet
<rect
       style="stroke-width:0.26458332"  <!-- inverse of stroke width = 3.7795  ?inkscape default stroke-width?-->
       y="0"
       x="0"
       height="80"
       width="80"
       id="rect28" />
Message 9 of 11
Nickduino
@Nickduino wrote:
my Inkscape v1.1
I don't know where I've seen that. It's 0.92
Message 10 of 11
HughesTooling
From some old posts i've read, Fusion is hard coded to work with Illustrator set to 96 DPI. Can't remember but there's some conversion from points or pixels and the DPI is part of the conversion.
It's pretty easy to scale once you have something imported. First select all curves and UnFix, measure between 2 points you know the size of then scale, enter the size you want divided by the size it measures. So if it measures 75mm and you want 100 just enter 100/75 as the scale.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 11 of 11
juricap
in reply to: HughesTooling
Confirmed the DPI of 96 idea. The required scale factor works out to 96/25.4 (approx. 3.77952)
