So I am a student in a BOCES program. We just purchased a Haas chip fan (we are a certified HTEC program so we have 6 super mini mills and 1 TM1P.). I was wondering how do I program this. I have it start at 2000 RPM and ramp to 7500. I also drew a figure 8 and I have it running a trace program. So my questions are is there a chip fan in the educational version of Fusion? Is trace the right type of tool path? How do I adjust the heights so it doesn't crash into my piece? Am I going at this completely wrong? Anything and everything is greatly appreciated. Thanks!
Please attach your model or if you do not have a model post a screen capture of what you are trying to achieve. If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
I would use a 2d Contour. I think the path will depend on what needs to be cleaned, but a race track shape would be a good place to start. Figure 8 won't work with a 2d Contour😀
ETFrench
