Repeating Actions many times
Andreas4WPLK
Message 1 of 16
Andreas4WPLK
I would like to repeat some basic tasks (like copying, translating and rotating at the same time) for a couple of dozen times. I'm building organic forms and want to see how they evolve by using very simple moves. So is there a simple way in Fusion to repeat such basic commands over and over again? I have attached a real model and a Fusion File to show what i'm looking for. IMG_20170913_171713.jpg
Replies (15)
Message 2 of 16
robduarte
I've been planning to make a plugin to do this but I haven't gotten around to it. I'm interested to know if there's something that already works (so I don't waste my time solving a non-problem).
Rob Duarte
Associate Professor in Art, Florida State University
Co-Director FSU Facility for Arts Research
http://art.fsu.edu/rob-duarte/
Twitter | YouTube
Message 3 of 16
SaeedHamza
If this picture is what you're trying to achieve, then you can simply use a sweep in the sculpt workspace and apply crease every fixed number of edges
If this is what you want, I'll make you a screencast to make things clearer
Regards
Saeed Hamza
Message 4 of 16
Andreas4WPLK
A plug in would be great. There is one for building spiral staircases but this is not what im looking for cause the parameters are different. I tried some stuff with parametric design inside fusion but have not found a good way to achieve my goal. I'll update you if I find some good ways.
The basic idea is still to move a object over and over again with the same parameters( and copying it at the same time). This should result in some fancy organic structures.
Maybe there are other programs which are better suited for this but i'm new to this and have no idea where to begin. I just use sketchup and fusion.
Message 5 of 16
Andreas4WPLK
I'm not sure but I'll check that out. Thanks. Like I said, I want a easy way to simulate what happens if you take a basic shape with an angle and do the same (Copy/Move/Align) over and over again. To see for example how a certain angle  changes the overall geometry.
And yes....a screencast would be nice.
Message 6 of 16
SaeedHamza
The closest thing to what you're asking for is the pattern with the type set to feature, but still won't give you what you need
Here is the screencast of the picture
Regards
Saeed Hamza
Message 7 of 16
TrippyLighting
What you're "really" are looking is a procedural way of modeling.
There is really no good way of doing thins with Fusion 360 straight out of the box. If you're proficient in Python, you could write a script that does this.
However, generally, procedurally generated  geometry has often a large amount of geometry and this would have the potential to slow down Fusion 360 substantially. You'd have to turn off the time line!
I am fairly certain this can be done with Rhino and it's powerful Grasshoper plugin.
I personally would attempt this with with Blender and it's array modifiers. If  that does not work Houdini would be my next choice.
Message 8 of 16
Andreas4WPLK
Thanks. I'll check it out later this day.
Message 9 of 16
Andreas4WPLK
I did some research and came to the same thinking. I'll stay with Fusion and try some other ways before taking such a "big" step. Do you know about Dynamo Studio...also from Autodesk. Isn't it similar to grasshoppers?
Message 10 of 16
laughingcreek
@TrippyLighting is right, procedural geometries isn't the type of thing fusion can do (for now?).  But if your going to stay with fusion, one approach would be to use components with joints.
-make the component
-place a joint origin in the component
-make copies
-use joints to put them together.
once done, you just have to make one change to the joint origin, and the way it all goes to gether will change
here are 2 screen shoots of the design, from the same perspective (based on the screen shot of your original)  the only difference is I went in and changed the rotation angle of the joint origin in the original component from 0 deg to 45 deg (just have to make the change in one place)
Message 11 of 16
robduarte
Give http://www.openscad.org/ a try. It has nowhere near the capabilities of Fusion 360, but it allows you to create geometry through its simple programming language. This is a perfect tool for what you're trying to do. It's pretty fun to use, too.
Rob Duarte
Twitter | YouTube
Message 12 of 16
Andreas4WPLK
That looks promising. I'll try that. Have never worked with joint so it will take some trying. Thanks.
Message 13 of 16
yang.zhou
Hi Andreas4WPLK,
You could try the feature "Pattern on Path" to see if it satisfies your requirement.
Thanks for trying.
Jerry
Fusion Development Team
Message 14 of 16
Andreas4WPLK
No it won't, because the path is what I want to se happening. If I would know the path in advance then it would work this way.
Message 15 of 16
Andreas4WPLK
This work more or less. Thanks. It is still tiresome because there is no way to make multiple copies of component including the joint. So I really have to link every single component. But this works for the moment.Bildschirmfoto 2017-09-15 um 15.37.49.png
Message 16 of 16
laughingcreek
You can take all those you've jointed together, drop them into another component so you have an assembly.  copy and paste the assembly, and join the assemblies.  still tedious, but you can grow it faster.
