Mouse Holes app/script
Felipe.G
Felipe.G
HI, Does anybody knows about an app/script for fusion that can make a "mouse hole" in one click?, is like the reverse of a fillet, instead of "rounding" the corner to a certain diameter or radius, the "mouse hole" "trim" the corner where selected, or even on 2D if is possible during sketch stage will help.
Thank you
Brady_Fulton
I don't know of a one click solution, but using the "hole" feature (shortcut key "h") and clicking on the corners will give you something similar.
SaeedHamza
This should be done using a sketch. I recommend you not to search for such shortcuts to achieving your goal, because it doesn't save that much time anyway
Regards
Saeed Hamza
laughingcreek
use the hole idea suggested by @Brady_Fulton.  you really want to avoid arcs and fillets in your sketches as much as possible.
Felipe.G
Thank you, is a great way to do some of it, but need more control, I have to do so many, but hope someone may have the talent for a script, autocad used to have a lisp for it.
Thanks for the ideas!
Brady_Fulton
If you still use autocad and have the lisp, you could also export a DXF of your flat pattern, import that into autocad and run the lisp routine on that.
