autodesk university las Vegas hands on
camstuff
camstuff
Does anyone know what the hands on with Fusion 360 classes will be this year?
I am looking to learn more on using heat simulations.
Thanks all
Cam
James.Youmatz
Autodesk Support
Autodesk Support
Hi @camstuff,
Great to hear you will be attending AU this year! I will see you there Smiley Wink Stop by the answer bar in the Exhibit Hall and meet the team if you get some free time!
Regarding Hands-On labs, check out the full class catalog here (the filters should be applied for Fusion and hands on labs, but you may need to apply them again).
Also (self-promotion) - I personally am presenting an instructional class on the powerful collaboration between EAGLE and Fusion 360. I'm demonstrating how to create a power supply and use the push/pull functionality between ECAD and MCAD using Fusion's thermal simulation. Although I won't be delving too much into the specifics of learning how to use thermal simulation - it may be an interesting class for you to attend! Plus, I always like meeting new faces! The class is labelled CP125149 - Designing a Power Supply: Iterating Between EAGLE and Fusion 360 Simulation.
Hope to see you there!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
