Rendering/ Graphics bug with revolved object and decals
eric_strebel
Message 1 of 10
eric_strebel
I have a revolved body with a transparent png decal applied to it. I have a dot that apears above the decal in regular model mode and it shows up when I render as well. I would like to place my decal on the center of the part, but this artifact shows up and covers part of my decal.Screen Shot 2016-01-07 at 2.59.57 PM.pngTowerdx7.png
Replies (9)
Message 2 of 10
PhilProcarioJr
Does the object have a bunch of faces that make a pole in the middle on that face or is it a single face?
I had this problem once before and had to do a planar projection on that face to fix it.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 10
eric_strebel
It's a single face revolved around the z axis, right were the anomoly occurs.Screen Shot 2016-01-07 at 3.43.02 PM.png
Message 4 of 10
joel.palioca
Hi Eric,
Are you able to attach the file so that we can take a look at it?  I tried a similar workflow on my machine and wasn't able to see the same problem, so I may have missed a step or there may be something specific to your model or values that we need to investigate.
Cheers,
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
Autodesk, Inc.
Message 5 of 10
eric_strebel
If you message me I would be happy to share the file to you
Message 6 of 10
Phil.E
Sorry for jumping in here, but does this have anything to do with "chain faces"?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 10
eric_strebel
I checked and turning cain on or off on my end deos not make a difference
Message 8 of 10
eric_strebel
I notice that you have that circel in the middle of your revolved object as well, just like i do.Screen Shot 2016-01-08 at 3.52.06 PM.png
Message 9 of 10
joel.palioca
This issue has been logged as 22093 and we are currently investigating it.
@eric_strebel Thank you for working with me to help figure this out.
Cheers,
[Joel Palioca]
Autodesk, Inc.
Message 10 of 10
brucehuang
@eric_strebel, thanks a lot for reporting the issue to us. Our QA had logged a bug for this. And it was fixed now. Hopefully the fix can go into the next release update. Thanks!
Bruce (Fusion Development Team)
