Render environment settings question - no more "Ground Scale" option?
eSonOfAnder
eSonOfAnder
Found this older post: https://forums.autodesk.com/t5/fusion-design-validate-document/environments-library/td-p/6545566
There is a reference there to a "Ground Scale" setting for the render environment, but I don't see that in my available options anywhere. Has this been removed?
laughingcreek
dependent on the environment.  for instance it's available with the field environment.
eSonOfAnder
Ahhh, that makes sense then. Thank you!
