Environments Library
bigonvalue
Message 1 of 10
bigonvalue
Newbie here:  I see that only a few environment images were included in F360 Library. Does anyone know where I can find more?  OR perhaps how to create and import my own?
Replies (9)
Message 2 of 10
I_Forge_KC
When you are in the environment select window there is a button at the bottom for attaching a custom environment.
Feel free to search online for HDRI environments and you'll be set! They often do require quite a bit of fiddling to get them scaled and positioned right though. Here are some of my favorite spots...
http://texturify.com/category/environment-panoramas.html
http://hdrmaps.com/freebies
K. Cornett
Generative Design Consultant / Trainer
Message 3 of 10
DWhiteley
Earlier versions of Fusion had these environments in the scene settings.
Are you now saying that you have removed these (such as field, crossroads etc.) and that we have to go & find our own. Retrograde step if you ask me!
Dave Whiteley
Envisage UK Ltd
Message 4 of 10
hoegge
But there IS now way to scale or position them, right? Just a primitive angle adjustment, which does not allow setting the right vertical position. The environment does not rotate with the view either? Pretty strange - almost seems like not implemented for real use.
Message 5 of 10
Yeah, I migrated to F360 to get AWAY from these kinds of business practices. It's a big deal when you wake up and your BUSINESS software has taken a feature away. Maybe Autodesk will add it back in
Message 6 of 10
I_Forge_KC
I'm confused...
These are still present. Nothing has changed...
K. Cornett
Message 7 of 10
Nice! Don't update
Message 8 of 10
DWhiteley
This was an old post.
Message 9 of 10
Oh I see. I don't think I'd restarted in a while. It took a few restarts
but the Environments are back. Thanks guys.
Message 10 of 10
sciblognet
Community Visitor
Community Visitor
Hey! I am a Civil Engineering Design Engineer working with a wide range of programs including AutoCAD. I will be grateful if you share the literature you use. I recently came across a good essay about environment and civil engineering https://envrexperts.com/free-essays/essay-about-introduction-civilian-conservation-
corps highly recommend checking it out. Regarding your question, it's worth using advanced plugins to solve these problems.
