How to remove a body which seems not be around anymore.
Not visible in the timeline.
Does it effect the speed of fusion360.
Can someone give me a solution
see attachments.
regards,
Pieter
Hi @Anonymous,
Will you please attach the file. I need to test it.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
Hi Ben
Attached the file
Let me know if it is not the way to provide you with this file.
regards,
Pieter
Okay, I've got some comment for you in the screencast. You gonna have to rethink how you are going to build this Ferry, because the way you did now, is not the right way.
This is the link to R.U.L.E #1 which you must follow!
Ben Korez
Facebook | YouTube
Thanks for your answer
I will check out rule #1
Then I think we will speak again.
Also have a happy New Year.
Greetings from Holland
Pieter
The body error is not removed yet.
Meanwhile worked on the sketches to say the frame lines
Now they are all fully constraint
It has cost many hours to do
Learned about tangent and curvature handles.
These tangent points are quite tricky curvature handle and points can lay very close to tangent handle midpoint.
A lot of zoom to check if you choose the correct point for dimensioning @#$%^&*
Why is er no option in F360 when wanting (FC) fully constraint sketches for automatically detecting points with are blocking (FC)
Now want to find out what cmd LOOK OUT in sketch panel can do for me.
I see some dimensions change colour but thats a flash ..............
Creating a face gives a distortion between two frames
Therefore I now creating a lot of water lines(WL)
I will use these as rails
I'm getting really frustrated to make these fully constraint too.
again : Why is er no option in F360 when wanting (FC) fully constraint sketches for automatically detecting points with are blocking (FC)
I didn't find it yet
I want have the hull shape as it is given on the PNG drawings
I 'm going to create a face which I can use as start component for hull planking, creating frames.
every 12" there is a frame to be modelled . configuration is : 2x 12"frames , 1x 12"spacing
Rudder Construction is removed
made one centre line (CL) sketch and one off (CL) sketch
