The body error is not removed yet.
Meanwhile worked on the sketches to say the frame lines
Now they are all fully constraint
It has cost many hours to do
Learned about tangent and curvature handles.
These tangent points are quite tricky curvature handle and points can lay very close to tangent handle midpoint.
A lot of zoom to check if you choose the correct point for dimensioning @#$%^&*
Why is er no option in F360 when wanting (FC) fully constraint sketches for automatically detecting points with are blocking (FC)
Now want to find out what cmd LOOK OUT in sketch panel can do for me.
I see some dimensions change colour but thats a flash ..............
Creating a face gives a distortion between two frames
Therefore I now creating a lot of water lines(WL)
I will use these as rails
I'm getting really frustrated to make these fully constraint too.
again : Why is er no option in F360 when wanting (FC) fully constraint sketches for automatically detecting points with are blocking (FC)
I didn't find it yet
I want have the hull shape as it is given on the PNG drawings
I 'm going to create a face which I can use as start component for hull planking, creating frames.
every 12" there is a frame to be modelled . configuration is : 2x 12"frames , 1x 12"spacing
Rudder Construction is removed
made one centre line (CL) sketch and one off (CL) sketch
