recording sim to avi
Message 1 of 28
what video compressor do I need to install for recording my sim results with windows ten  ? I can make a file but can't play the file I am getting now .
thank you
tony
Replies (27)
Message 21 of 28
@tomas.bujnoch wrote:
Issue was brought to the wider audience on our developers meeting and conclusion is:
1. We'll fix this issue, so the recording works in the same manner as in Fusion360.Animations.
2. We'll try to push this fix into hotfix. Since it is a customer issue, it should make it, still "We'll try" doesn't mean, it will be there for sure. Depends on the decision of reviewers. Hotfix is expected to be released 26.9.2015.
3. If the fix doesn't make it into hotfix, it will come out with regular release. Regular release is expected to come out during November 2015.
where all the win 10 issuse brought up listed in this thread ? I know enought about windows and coding not to start crying why isn't it fixed yet .
thank you
Tony
Message 22 of 28
tomas.bujnoch
Nope. I took a care just about video recording.
Josef, would you please take care about the droping of the files?
Thanks!
Message 23 of 28
josef.kucera
Hi Tony,
I have let our devs to know about your issue with dropping files to upload and they will contact you soon.
Josef
Josef Kucera
Fusion QA
Message 24 of 28
scott_morrison
Hi Tony,
You mentioned "can you add in an issue with droping files to upload and links that would open in a web browser are not working with my install under windows ten".
Can you please give more details on the problem? I tried dragging a file from the Explorer on Windows 10 to the Fusion 360 upload dialog, and it worked for me. Also, what is the issue with links that won't upen in a web browser.  Which links have this problem?
Which browser are you using as your default browser in Windows 10?
-- Scott Morrison
Message 25 of 28
hi scott , sorry for the late responce I didn't see the notafacation ,
with crome the links that would go to the browser would not open and with edge it works fine . as for the drag and drop  , I turned off my av and tryed with no luck . when you try and drop the file I get a round circle with a line thru it  .
tony
Message 26 of 28
scott_morrison
Hi Tony,
When I access links from the Fusion360 data panel on WIndows 10, they work on both Chrome and Edge.  I'm also able to drag file from the Windows Explorer to the upload dialog, and it works.
I've got a fiew more questions for you.
1. What version of the Chrome browser are you running?
2. Can you please list the exact steps you are trying for drag and drop?
3. What file type are you trying to drag?
4. You mention below "I turned off my av".  What does that mean?
Here are the steps I took to get drag and drop to work on WIndows 10;
1. Press on the "Upload" button in Fusion360.
2. Open the Windows Explorer using the button on the Windows 10 task bar.
3. Browse to a design file that Fusion360 knows about (I used a .f3d file).
4. Drag the file from the Explorer to the Upload dialog "Drag and Drop Here" area.
-- Scott
Message 27 of 28
ok scott ,
I did the same steps as you did, The difference is I used a dxf . I got the same result as before black circle with a line throw it .
chrome is Version 45.0.2454.101 m
I am glad your update to windows ten has allowed you to use fusion with out problems .
I do have enough of an IT background to know that what works on ones windows machine may not work the same on the next .
AV = antivirus
Tony
Message 28 of 28
problem patched in fusion !
