recording sim to avi
Message 1 of 28
what video compressor do I need to install for recording my sim results with windows ten  ? I can make a file but can't play the file I am getting now .
thank you
tony
Replies (27)
Message 2 of 28
Edit : video from animation works outputs working avi files , I just tested !
Message 3 of 28
josef.kucera
Hi Tony,
glad to hear that you are playing with simulations and that animation recording eventually worked for you on win 10.
Josef
Josef Kucera
Fusion QA
Message 4 of 28
Hi Josef,
The sim avi export is not working , but the animation does .
Tony
Message 5 of 28
josef.kucera
Hi Tony,
sorry for missunderstanding, I will report it to our Devs tomorrow and will keep you updated.
Thanks for you patient so far.
Josef
Josef Kucera
Fusion QA
Message 6 of 28
can you add in an issue with droping files to upload and links that would open in a web browser are not working with my install under windows ten . everything was working before the update to win ten . I am not sure what is blocking it
thanks
tony
Message 7 of 28
josef.kucera
Hi Tony,
sorry to hear that, could you please install latest Chrome browser and make it a default for viewing web content if it helps with the issue you are having?
Josef
Josef Kucera
Fusion QA
Message 8 of 28
yes that has been done before posting about it . I do understand the need to ask on your part .
Message 9 of 28
tomas.bujnoch
Hi Tony,
Wrt unability to play the recorded avi: Please, make sure you don't use the default "Movies & Tv" win 10 application. Rather use "Windows Media Player". If you captured your video using Microsoft video 1 codec, you should be able to play your videos. Well, this codec is kind of outdated. Just annoying, we'll have to fix it. Sorry for the inconvenience.
Anyways, alternativelly you can install some of freely available codec packs and then you can just pick the codec by your preference. As long as they are supported by "Movies & Tv" app, you should be able to play your recordings.
Message 10 of 28
yes but in video compression  dialog has no options in the drop down for compression type still .
Message 11 of 28
Message 12 of 28
tomas.bujnoch
There is a Configure button for the listed codecs. If codec installed properly, the compression type - or better to say codecs configuration - can be adjusted.
Message 13 of 28
the latest ver of divix and handbrake where installed today with restart of windows . so what did I miss ?
Message 14 of 28
tomas.bujnoch
I've just tried Xvid MPEG-4 codec installed together with K-Lite codecs pack. Seems to be working nicely.
Message 15 of 28
ok it has to be a windows issue i still don't see anything after the install and restart
Message 16 of 28
tomas.bujnoch
I've just reminded - I'm also having VLC installed. I wouldn't put a bet on that, but maybe VLC makes the difference.
Anyways - it's just not the nice behavior for the app, that tries to simplify things. We'll have to do something about that. The recording workflow simply seems to be too complex. That's all I can say/do right know. I can't predict, how this evolves, but I'll give you to know back.
Message 17 of 28
I just installed vlc with the same result . I may to do a clean install of fusion . this is nut I am sure it is windows being a pain .. I will laugh if it works after the computer is off over night as used to be the case with older versions .
Message 18 of 28
why would one part of fusion output a avi file and the other would not ?
Message 19 of 28
I reinstalled fusion and same problem , I installed on win 8.1 worked as should
Message 20 of 28
tomas.bujnoch
Issue was brought to the wider audience on our developers meeting and conclusion is:
1. We'll fix this issue, so the recording works in the same manner as in Fusion360.Animations.
2. We'll try to push this fix into hotfix. Since it is a customer issue, it should make it, still "We'll try" doesn't mean, it will be there for sure. Depends on the decision of reviewers. Hotfix is expected to be released 26.9.2015.
3. If the fix doesn't make it into hotfix, it will come out with regular release. Regular release is expected to come out during November 2015.
