Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
"Mesh, T-spline and surface bodies will not be included in drawing"
2 REPLIES 2
260 Views, 2 Replies
When I go:
Design>Drawing>From Design
It says: "Mesh, T-spline and surface bodies will not be included in drawing"
How do I fix it?
2 REPLIES 2
jeff_strater
you cannot "fix" this.  It is a limitation of the drawing environment today - only solid bodies can be included in drawings.
Jeff Strater
Engineering Director
TrippyLighting
Perhaps if you can explain in more general terms what you are trying to do and share a screenshot of the design, or even share the model we can provide better advice.
E.g. T-spline and surface models can be thickened and then you can create drawings from them.
