Help prepare a complex mesh for 3d printing
09:36 PM
I need to make the mesh a solid, so I can 3d print this. It's a front bumper for an RC car.
If you can open the attached. I copied the first mesh, then moved it 1mm inside. The inside mesh, I performed "Reverse Normal", because I want it to be the back of the surface. I also scaled down the inside mesh a small amount (.99). Now I simply need to fill the gaps in between both meshes to make it a solid!
Any help appreciated! Thank you very much!
-Chris
