Project to surface error
jamesward0001
Message 1 of 9
jamesward0001
Hi, I am quite new to fusion 360 but have been using solidworks previously and I am coming upon a probblem I can't seem to find any info about on the forums.  Basically, I am trying to project a complex sketch onto the side of a cone shape and it gives the error: "Have certain selected curves couldn't be projected!" and only about half of the design gets projected onto the surface.  The situation improves with project to surface (along vector) as a few more of the lines project but it's still not projecting all of them.  Any ideas?  Please don't hesitate to ask if you need any more screenshots / clarification.
Thanks in advance
Replies (8)
Message 2 of 9
SaeedHamza
please provide us with your f3d file
Saeed Hamza
Message 3 of 9
jamesward0001
This should be the f3d file
Message 4 of 9
SaeedHamza
Here are some pictures for a mosaic projected on a cylinder, check them out
regards
Saeed Hamza
Message 5 of 9
SaeedHamza
good I'll take a look
Saeed Hamza
Message 6 of 9
SaeedHamza
I noticed that you mean that you want to project the sketch on the cylinder, but I recommend you use project from surface, but still your sketch has some problems, the main problem is in the crown ...
here is a picture of the result I got after fixing somethings from your sketch ...
please check the file attached
kind regards, Saeed
Saeed Hamza
Message 7 of 9
jamesward0001
Hi, the work you have already done on this is fantastic! but i was wondering if you could give me any pointers on what's broken in the crown so i can fix it?  Thanks!
Message 8 of 9
SaeedHamza
I found your problems, check these picture please
Kind regards, Saeed
Saeed Hamza
Message 9 of 9
jamesward0001
Thanks so much for all of your help, got the whole thing fixed now and can print it on my 3d printer
