Render certain faces
Hey!
I am new to Fusion 360 and I am wondering if it is possible to render certain faces in the "render mode". When I do it in sculpt it works, but when I go to render mode it disappears. The render mode makes its own faces that doesn't match the faces I have in sculpt mode. As you can see in the picture I can't choose the same face as in sculpt mode.
By render I mean change the appearance.
I appreciate all answers 🙂
SaeedHamza
Yes the faces are not the same after exiting the sculpt environment, so I recommend you use split faces to get the desired face
Saeed Hamza
SaeedHamza
I took a look into your design and here are some pictures to help you out get what you want:
1-create 2 bodies in the sculpt environment, one of the main car and one of the glass ( to render them separately )
2-use the split body/face tool to cut the glass body into 2 or more bodies according to what you plan to render
Check pictures below ...
Thanks, Kind regards
Saeed
Saeed Hamza
