Project a component into a design, copy it, and then remove it
- Mute
- Permalink
- Report
I'm trying to reproduce a portion of a complex component in a different design, but I don't want any references or mentions of the original design (or component) in the new design. While I've tried many different approaches to solve this, I've still been unable to create the new design. Ideally, I would be able to follow a workflow similar to below:
1. Create a new design (D_new)
2. Derive from a component (C_old) in a different design (D_old)
3. Create a new component (C_new)
4. Create a new sketch (S_new)
5. Project C_old into the sketch (S_new)
6. Use the projected geometry to create new geometry
7. Remove the projection
8. Remove all traces of C_old and D_old
While I'm able to get through steps 1-6, I'm not able to find a way to perform steps 7 or 8. I can sometime "delete" the old component (C_old), but it still appears in the history. If I was able to create a list of all lines, circles, and other shapes in the old component (C_old) and then easily type those shapes into the new component (C_new) that would also work (even if it is more effort).
Does Fusion 360 provide some way to create a "netlist" for a sketch? If I could just get a list of the individual geometric shapes and then have a way to reproduce that list, it would be enough. However, I've basically run out of ideas trying to get this to work (at least with a clean history).
