Problems with photo quality rendering of materials
kevinwatts
Message 1 of 9
kevinwatts
Hi Colin,
I am having a hard time to get the photo quality that I am after and need in my shots and need your  assistance.
My main exterior appearance material is a White Plastic (glossy). I have tried a transparent acrylic and that material looks very real. I have tried rendering local in Fusion and through the A360 cloud. Can you please suggest what I can do to achieve a photo smooth gloss white plastic finished look within Fusion?
Perhaps a different material or settings as discussed in your article: Making it Look Good: Apply and Edit materials in Fusion360?
Much appreciated,
Kevin
Replies (8)
Message 2 of 9
colin.smith
Hi Kevin,
Just a heads up, I moved this message out to it's own thread so that it wasn't part of your other question.
Is it the rendering results of the material Plastic > Opaque > Plastic >Glossy (White) in particular?  Or the rendering engine (cloud or local) you are using?
Can you show a screen shot of the issue?
I was running some tests on that material and I'm not seeing issues in cloud or local renders.
Colin Smith
Sr. Product Manager
SketchBook
Alias Create VR (aka Project Sugarhill)
Automotive & Conceptual Design Group
Message 3 of 9
cekuhnen
can you show a rendering you did?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 4 of 9
cekuhnen
Colin I think the struggle here is the lack of scene design abilities.
White materials are very hard to do in a white environment because the white plastic will show white reflections on a white part 😉
Kevin could you try this out: put up some reflection walls (black dark gray color) into your scene till they show up in the reflection?
Claas Kuhnen
Message 5 of 9
colin.smith
Good point,
Other options could be to change the backgroun colour or to create light objects with emitting materials.
We will be providing actual light objects in a future release but this can help in the short term.
Colin Smith
Sr. Product Manager
SketchBook
Message 6 of 9
kevinwatts
Hi Colin & Claas,
I appreciate, will try your sugestions and post back.
Kevin
Message 7 of 9
kevinwatts
Hi Colin,
Thank you for moving this message out to it's own thread.
I am rending with the appearance material of: Plastic > Glossy (White). And I have tried rendering both local and cloud.
From the comments and you picture, I think that part of the problem is that I am shooting white on white. I am trying to convey a very "cleantech" appearance to the product. A contrast and reflections are needed to add depth and a reflective perception.
Due to the confidential IP of the project during development, I can not post a view. I can add you to the project if you would be so kind a take a fast look. I think that it would be best if you could see what I am doing and then be in a better position to recommend some options.
Kevin
Message 8 of 9
bob_holland
Autodesk Support
Autodesk Support
@kevinwatts,
Can you create the same effect that you are seeing with some simple unrelated geometry that you can share with us?
Thank you.
Bob Holland
Autodesk Product Support
Message 9 of 9
kevinwatts
Here are some fast local renders on a sphire. The contrast and reflective qualities are what addes to the realism.
Plastic Glossy White Render Test 1 - Style:Rim Highlights, Exp:0.0, Rotation:0.0, Background:Environment, Quality:Normal, Time:120 sec.
Plastic Glossy White Render Test 2 - Style:Rim Highlights, Exp:0.0, Rotation:0.0, Background:Black, Quality:Normal, Time:120 sec.
Plastic Glossy White Render Test 3 - Style:Warm Light, Exp:0.0, Rotation:0.0, Background:Black, Quality:Normal, Reflect:Ground, Time:120 sec.
Plastic Glossy White Render Test 4 - Style:Warm Light, Exp:0.0, Rotation:0.0, Background:Black, Quality:Normal, Time:120 sec.
