Help return browser to transparent background
yoshimitsuspeed
Advisor Advisor
yoshimitsuspeed
Somehow my browser got moved to it's own window. Don't even know how it happened. It did happen once before and after searching I found an answer how to fix it but not this time. I posted an idea in the idea station that this needs to be improved and asked how to fix it there but got no replies.
So for now I just need to know how to return it to it's default location with the transparent background.
Beyond that it should really be easier to figure out how to do this. Something simple and intuitive like right clicking on the title bar or background and selecting a return to default option or something. Or even just double clicking the title bar or background or something.
I know Autodesk doesn't seem to like easy or intuitive but you guys might look into it sometimes.
https://www.facebook.com/groups/1229995573786339/
schneik-adsk
Will definitely look into it.
For now, grab the browser title bar and drag it to the edge of the app frame where you want it docked. A green line will show that you are in the dock drop zone.
IF you want to reset everything to the default view, you can access the file menu -> view -> reset to defaults.
All UI will pop back into into the default position.
Kevin Schneider
yoshimitsuspeed
Might I suggest changing it so when the corner of the box hits the edge of the frame or something?
I have spent probably 15 min clicking on this thing, dragging it around etc. Maybe it's just me but it never would have occured to me to drag it off the screen until the mouse was at the edge of the frame. I have dragged it off the screen and back on but the green line must have flickered so fast I didn't notice it.
I also tried dragging it all around the area where it was originally docked but again I would assume it was associated with the bar above it and not the frame edge but again maybe that's just me.
Thanks for the help though. I Knew about resetting it but just couldn't remember where. Hadn't heard about the green line though.
Thanks.
