Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Problems with importing svg file
15 REPLIES 15
Message 1 of 16
2702 Views, 15 Replies
Hi all,
I have some complex adobe illustrator design with very precise measurements. One line is for example exactly 10,2cm
When I import the svg file into a new fusion file using the insert svg tool, the scale is all wrong and the before mentioned line is 7,65 cm.
To go from 7,65 to 10,2 you need to multiply by exactly 1,333333333 which cannot be a coinsidence... In the insert svg dialog I notice there is a scale option, but if I add 1,3333 here my line ends up being 13.95 cm.
So my question: how can I get my svg to a proper scaled sketch in fusion 360?
Pictures of every step I took from illustrator to fusion 360 attached below.
Screenshot 2016-09-07 18.18.11.pngScreenshot 2016-09-07 18.18.58.pngScreenshot 2016-09-07 18.19.40.pngScreenshot 2016-09-07 18.20.38.png
Hi all,
15 REPLIES 15
Message 2 of 16
HughesTooling
HughesTooling
Can you attach a simple SVG you've drawn, just a 100mm square would do. From your description something strange is going on with the insert scale option so have you tried scaling after import?
Mark
Mark Hughes
Owner, Hughes Tooling
Mark
Mark Hughes
Message 3 of 16
in reply to: HughesTooling
Hi Mark,
Thank you for getting back to me so fast!
Attached is the file I used in above screenshots
It contains some pretty easy shapes, that should illustrate my point.
Does this help?
Hi Mark,
Does this help?
Message 4 of 16
Mark,
What do you mean by scaling after import? Is it possible for me to scale an entire sketch at once?
If yes, how?
Mark,
If yes, how?
Message 5 of 16
HughesTooling
HughesTooling
@Anonymous wrote:
Mark,
If yes, how?
After inserting the SVG while still in sketch mode window select all the curves, it will take a few seconds with your SVG. Click the unlock icon on the Sketch Palette dialog then select scale from the Sketch menu, pick a base point then a scale factor.
Mark
Mark Hughes
@Anonymous wrote:
Mark,
If yes, how?
Mark
Mark Hughes
Message 6 of 16
Hi Mark,
I cant see the unlock button in the sketch palette and I am a bit confused what to do with the sketch scale dialog.
What I did:
1. Import svg
2. Select everything by drwaing a square around everything with the select tool
Could you please clarify?
EDIT: now with screenshot
Hi Mark,
What I did:
1. Import svg
Message 7 of 16
HughesTooling
HughesTooling
Sorry should have said Unfix, got confused using too many CAD programs at the same time.Smiley Wink
Not sure why you have no scale option on the sketch menu, have you got the latest update?
Mark
Mark Hughes
Mark
Mark Hughes
Message 8 of 16
I have version 2.0.2377, if not the latest it should be very recent.
What do I do?
PS: I do not see an option unfix either?
Where are these things?
What do I do?
Message 9 of 16
I_Forge_KC
I_Forge_KC
Take a look here...
K. Cornett
Generative Design Consultant / Trainer
Take a look here...
K. Cornett
Message 10 of 16
HughesTooling
HughesTooling
@jeff_strater Here's an odd bug, if you import the SVG attached to this thread and scale by 1.3333 then import without scaling then scale with the scale tool from the Sketch menu you get a different result. @Anonymous points out in his first post that the scale on the import dialog is giving the wrong result. Screencast to demonstrate the difference.
Mark
Mark Hughes
Mark
Mark Hughes
Message 11 of 16
I_Forge_KC
I_Forge_KC
Yeah there is a math error there...
The scaling in the SVG dialog box is applied twice.
K. Cornett
K. Cornett
Message 12 of 16
jeff_strater
in reply to: I_Forge_KC
jeff_strater
Yep, that's a bug, all right.  Good catch.  We'll get that one entered and fixed.  It should be easy enough to fix (famous last words).
Jeff
Jeff Strater
Engineering Director
Jeff
Jeff Strater
Message 13 of 16
in reply to: jeff_strater
I bet finding a bug in an autodesk program instantly promotes me to like level 5 on the forum? ;o
Message 14 of 16
Hi @HughesTooling @I_Forge_KC
Even though there was a bug, I am really impressed with how fast you guys answered my question and how clear your answer was with the video and everything.
Thanks a lot - well happy with my first autodesk experience.
Message 15 of 16
ShirleyShi
ShirleyShi
I think it is the same issue with another link. The 1.3333333333 is actually 96/72. See detail explanation in the post 9 and 10 in: http://forums.autodesk.com/t5/design-validate-document/svg-scale-is-wrong/m-p/6567298/highlight/fals...
Shirley
Developer for Fusion Electronics
Autodesk, Inc.
Shirley
Autodesk, Inc.
Message 16 of 16
aron.santa
aron.santa
Community Visitor
Community Visitor
.dxf works...
.dxf works...
