Message 1 of 16
09:23 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I have some complex adobe illustrator design with very precise measurements. One line is for example exactly 10,2cm
When I import the svg file into a new fusion file using the insert svg tool, the scale is all wrong and the before mentioned line is 7,65 cm.
To go from 7,65 to 10,2 you need to multiply by exactly 1,333333333 which cannot be a coinsidence... In the insert svg dialog I notice there is a scale option, but if I add 1,3333 here my line ends up being 13.95 cm.
So my question: how can I get my svg to a proper scaled sketch in fusion 360?
Pictures of every step I took from illustrator to fusion 360 attached below.
