Feedback requested - highlighting solutions in forum threads
brianrepp
Community Manager Community Manager
Message 1 of 87
brianrepp
I'm looking to get community feedback on the possibility of highlighting solutions in a thread, similar to what's done on the rest of the Autodesk forums (example here).  Do you think something like this would help ease locating the solution, and as a byproduct, increase adoption of marking a thread as "solved"?  Or, would it just add clutter?  Fire away with feedback!
Here is how it looks on the A360 forums (along with the actual posted solution being marked green in the thread):
Replies (86)
Message 2 of 87
Solar-emc
YES, I VOTE YES!
I got to say this is one of the best forum tools out there.
Also please alow editing one's post at any time. A day after post, 30 days a year ANYTIME one should be able to edit there posts, attachments as well.
Please improve the "How you find your own posts"
Message 3 of 87
brianrepp
@Solar-emc - as for editing, about a month ago we gave the original poster of a thread the ability to edit their post indefinitely as a trial to see how it goes.  The one problem with editing posts in the middle of a communal discussion thread is that conversations can start to lose their context if users are editing posts that other users are replying to.  If this were strictly a Q&A site, it might be more acceptable, IMO.
Message 4 of 87
Oceanconcepts
Yes- that would be helpful.
One issue, though, is that sometimes a solution is not a solution. What I mean is that if a post identifies a problem in Fusion, something one just can't do, that requires an extensive workaround, or that doesn't work properly, and someone helpfully points that out, the problem may be illuminated, but not exactly solved. And sometimes there are multiple solutions. But as a means of highlighting helpful posts, yes, definitely.
- Ron
Mostly Mac- currently M1 MacBook Pro
Message 5 of 87
Oceanconcepts
@brianrepp
One suggestion that might help us all (which I understand might not be technically feasible) would be to give the option to add to or append your post, but not delete anything. Sometimes the ability to correct misstatements or provide additional information would greatly help clarity, and by one way editing you could do this without losing the context in the original.
- Ron
Message 6 of 87
brianrepp
Thanks for the feedback, Ron.  I believe there actually is an option to accept multiple posts as a solution, but similar to what you point out, there sometimes isn't ever such a thing as a solution to a particular thread.  I do believe there has been discussions with Lithium previously about allowing additions to a post (but no removal), but i'd say in the meantime the suggested practice is to notify the moderator who has no problem making edits to a post for a user (obviously not everyone will know about this though).
Message 7 of 87
Yes, I think highlighting the solutions would be good.
Message 8 of 87
daniel_lyall
have 3 option for solved
solved with work around.
partly solved
solved.
and have it so the OP can remove solved if someone comes along and solves it when it is not solved this has happened a couple of times.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 9 of 87
Stuart-H
Yes please 👍👍👍👍👍👍👍👍
Mac Studio M1Max and MacBook Pro M1
Message 10 of 87
PhilProcarioJr
@brianrepp
I think @daniel_lyall hit the nail on the head here and if this is implimented then your proposed solution would be much appreciated.
"have 3 option for solved
 1) solved with work around.
 2) partly solved
 3) solved.
and have it so the OP can remove solved if someone comes along and solves it when it is not solved this has happened a couple of times."
As to editing posts...I just want to be able to "ADD" to existing posts.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 11 of 87
daniel_lyall
thanks @PhilProcarioJr there nothing worse than being told off for solving someone's problem when a hacker did it and it was not solved.
Add to is a good idea
Daniel Lyall
The Big Boss
Mach3 User
Message 12 of 87
HughesTooling
There's already an option for this.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 13 of 87
Beyondforce
Hi @brianrepp,
I like the idea of highlighting the Solution AND giving the option for the type of a solution.
BTW, I don't know if it's only me, but it takes a long time for the forum site and for the posts to open. Sometimes it takes up to 7 seconds to open.
I'm 100% sure that it's not my internet connection. I was thinking, maybe it's because I'm outside the US and you don't have a cache server in Europe!
Cheers / Ben
Check out my video channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 14 of 87
brianrepp
Thanks @Beyondforce.  For the delayed loading, have you tried clearing your browser cache?  I was running into the same issue last week, and after clearing, it's been smooth sailing.
Message 15 of 87
Beyondforce
Yes @brianrepp, I have also tried it on my FireFox which I'm not using that often and the cache there is clean 😞
Ben Korez
| YouTube
Message 16 of 87
HughesTooling
I've been meaning to make a post about the slowness of the forums as well, don't know if it's just in the UK. I use 2 different ISPs and 3 different computers, all slow. It's not just the forum the screencast website's slow as well. I remember a comment on the CAM forum before the switch to the lithium forum about how much slower the lithium forums are. Most pages on other forums open in 2-3 seconds here it can be more than 10, also get quite a few "This page is not responding, Kill page" errors. Time of day seems to make a difference so I don't think the problem's at my end.
I had to clear my cache a while ago because I couldn't log into the screencast form and didn't notice any difference in the speed on the forum.
Mark
Mark Hughes
Message 17 of 87
PhilProcarioJr
@brianrepp
I'm seeing the same issue with the forums being slow and I have cleared my cache also. Both at work and at home on 4 different computers all with a very fast internet connection.
Phil Procario Jr.
Message 18 of 87
Beyondforce
@brianrepp, so it's good that I brought it up.
I thought I'm going crazy! I have ordered a new internet connection and it will be installed tomorrow (not just because of that), I thought, maybe it will help 🙂
Ben Korez
| YouTube
Message 19 of 87
PhilProcarioJr
@Beyondforce
It wont....Smiley Sad
Phil Procario Jr.
Message 20 of 87
Beyondforce
@PhilProcarioJr, I have been drinking a lot of coffee lately because of that. Instead of staring on the screen and waiting for the forum page to finish loading, I was taking a break making coffee.
No wonder my skin is so brown 😉
Ben Korez
| YouTube
