Feedback requested - highlighting solutions in forum threads
brianrepp
Community Manager Community Manager
Message 1 of 87
brianrepp
I'm looking to get community feedback on the possibility of highlighting solutions in a thread, similar to what's done on the rest of the Autodesk forums (example here).  Do you think something like this would help ease locating the solution, and as a byproduct, increase adoption of marking a thread as "solved"?  Or, would it just add clutter?  Fire away with feedback!
Here is how it looks on the A360 forums (along with the actual posted solution being marked green in the thread):
Replies (86)
Message 41 of 87
brianrepp
@Beyondforce - also very helpful.  Would you mind sharing a snapshot of your connection speeds?
@Beyondforce and @daniel_lyall - curious, do you notice the same kind of lag with other Autodesk forums outside of Fusion?  For example, AutoCAD or Inventor or something like that?
Message 42 of 87
Beyondforce
@brianrepp, to be honest, I'm not active in other Autodesk forums, I have F360 what else do I need 😉
This is my internet speed:
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 43 of 87
brianrepp
@Beyondforce thanks for that.  At some point would you mind trying to browse around on one of those forums and let me know if you see the same performance issues?  http://forums.autodesk.com/t5/inventor-forum/bd-p/78  and http://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Message 44 of 87
Beyondforce
I was just browsing around and my initial experience is almost the same, especially in the Ideas site it is very noticeable like in Fusion.
But remember, the performance is changing all the time. Right now, it's somewhat ok, but in 5 minutes it can get much worse.
Ben Korez
| YouTube
Message 45 of 87
PhilProcarioJr
@brianrepp
I see it on all ADSK forums, but like @Beyondforce said it gets worse at times and right now it's not too bad but still slow.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 46 of 87
daniel_lyall
@brianrepp at the moment fusion forum is faster than the two forum's you posted.
same laptop for everything.
speed test at home as you can see not fast at all.
I will do one at the workshop tomorrow
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 47 of 87
PhilProcarioJr
@brianrepp
This morning it's pretty bad.
Phil Procario Jr.
Message 48 of 87
brianrepp
@PhilProcarioJr - thanks for posting that.  In this video it looks like loading the main board is taking upwards of 20 seconds, but loading an individual thread is within a second or so.  Is that accurate?
Message 49 of 87
PhilProcarioJr
@brianrepp
Loading the main board for me is always longer then an individual thread, but it also depends on what is in the thread along with how many posts are in the thread.
So if the thread has a lot of links and images in it then it takes longer.
Also posting takes a long time and things like screencast tab and showing my screencast to insert takes a long time.
Surprisingly inserting images doesn't.
Phil Procario Jr.
Message 50 of 87
brianrepp
All - have you noticed any improvements in speed in the last 12-24 hours?  The vendor made a few changes that are believed to have helped improve performance a bit.
Message 51 of 87
Beyondforce
@brianrepp, Unfortunately I don't feel any different. The site is still loading very slowly including the Idea station.
Sorry!
Ben Korez
| YouTube
Message 52 of 87
Beyondforce
@brianrepp, another thing is, it might be your Database. I have seen it before. You need to make sure that there is not latency between your DB and the Web server!
Ben Korez
| YouTube
Message 53 of 87
Beyondforce
@brianrepp, The forum is extremely slow today 😞
Ben Korez
| YouTube
Message 54 of 87
HughesTooling
Still seems as slow as before I thought I'd give it a few days before reporting back.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 55 of 87
daniel_lyall
At the workshop it's still the same won't work for a long time. only way to get it working is a refresh and it works but slow same as the vids. at home fine
Daniel Lyall
The Big Boss
Mach3 User
Message 56 of 87
HughesTooling
Here's another problem I get on the Autodesk forums that I don't get anywhere else. Doesn't happen that often lately maybe once or twice a week.
Mark
Mark Hughes
Message 57 of 87
brianrepp
Thanks, everyone.  @HughesTooling i assume this is because the page is taking so long to load it's eventually timing out?
Message 58 of 87
HughesTooling
The one I got today came up quite quickly then cleared itself after a few seconds. In the past when it's happened the page\tab would be frozen and needed to be closed. It seems to happen after pressing the back button or clicking the forum from the breadcrumbs, as you can see in the screengrab the page I was on loaded OK.
Mark
Mark Hughes
Message 59 of 87
check out http://livecustomwriting.com/blog/10-common-mental-problems-of-students that tells about common mental students problems!
Message 60 of 87
g.romeo
Yes, I agree!
