- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Someone in the CAM forum was having some problems with some circular slots. I traced it back to a circular pattern, in the example below I have one slot drawn, closed and constrained. The copies are all open. Also shows a problem with the constraint highlighting as as far as I can tell the first slot is fully constrained. File attached without pattern.
Mark.
Edit. Here's the link to the CAM forum thread. if you open the file in post #5 go to the model workspace and run compute all the slots disappear.
Mark Hughes
Owner, Hughes Tooling
