Bug in Pattern on Path
I want to use the pattern on path tool, but it doesn't behave as expected.
Initially it looks like this:
During the pattern on path command the preview looks perfect:
But when I hit okay, everything gets screwed up. I believe that the path gets mirrored somehow:
Am I missing something or is this bug?
gautham_kattethota
This is definitely not right, might be a bug.  Could you attach the file please so we could take a look.
Gautham
Gautham Kattethota
Software Development
I attached the version where the pattern on path tool isn't used yet.
Jacky-Li
this is a known defect and should have been fixed. you can check by next release
Is there an easy way around this?
wilkhui
Hi rvaaler - a fairly straightforwad (if inelegant) workaround is to edit the spheres so that they're new bodies and then use combine to cut them out:
Cheers,
Indy
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
