Problem with component visibility
jeffescott
Advisor Advisor
Message 1 of 8
jeffescott
Some of my components, are normal visibility.  That is solid with no hidden edges.
Others are faint with hidden edges.
I have no idea why these components are different.
I have been living with this for a while, but now I want to complete an assembly and find it difficult to deal with all the hidden edges I end up with.
Please see component Tri spring (solid) versus components Lip roller shoe (not solid), and latch lever (not solid)
Accepted solutions (3)
Replies (7)
Message 2 of 8
jameswVTJ5V
The parts that are semi transparent have their opacity setting turned down...
Right click the component/body and choose opacity control..
Message 3 of 8
g-andresen
Components opacity has priority over body opacity.
günther
Message 4 of 8
jeffescott
Thank you....I wonder how I ever changed that setting???
Learned something today.
Message 5 of 8
laughingcreek
there's a bug that's been floating around for quite some time now where there opacity of a component will stay low or get set low when changing component activation.  I've seen it many times, but have yet to figure out a repeatable sequence of events that causes it.  it just seems random.  AD knows about it, but I think until someone can find a way to reliably repeat the problem, it won't get fixed.
Message 6 of 8
jeffescott
Nice to know
Message 7 of 8
jeffescott
It did it again right after I did the latest update....
Now setting the opacities to 100% doesn't work.....I tried all the components for top level to bttm level no luck.
Guess I m Stuck with it till maybe the next update
Message 8 of 8
laughingcreek
AD isn't going to fix it till they get a repeatable scenario, so you could be waiting a while.
does it persist after closing and reopening?
you're sure you've got the top level component activated?
can you attach the the .f3d file?
