Unable to sculp an existing model
buruzs_daniel_peter
buruzs_daniel_peter
Hi, this is my first time asking about a problem here, i will try to be informativ. And sorry for my grammar.
So, as the title says, i cant sculp an already existing model. I had previusly used that function in Fusion, the scupling, but now i cant. I cant convert my whole model or if i do whit just one face there only will be added a new face on the old one and i can just "pull it off". There were a "putton" on the history bar, where i could acces the mode but now its gone and there is only a grayis icon.
laughingcreek
that feature in the timeline is called a base feature.  you can have geometry inside of it, but there won't be a timeline.  it's probably inside of there.  double click it to activate and edit.(or right mouse click and select edit)
buruzs_daniel_peter
Thanks for the tip but its still not working.
johnsonshiue
Hi! I believe you are talking about manipulating in Form (Tspline) environment. You need to use "Create Form" command first. Then convert the existing geometry to a form object.
Many thanks!
Software Test Engineer
HughesTooling
@buruzs_daniel_peter In the future can you paste the images into the message rather than attaching as it's easier to read.
I've never seen this message before, when and how did you get this message?
Mark Hughes
Owner, Hughes Tooling
buruzs_daniel_peter
I created a "dummy model". And from that a generativ one. When i open the generativ model, thats when this message come up.
buruzs_daniel_peter
Thank you, this kind of working, this still not solve all of the issues but i can work with this.
