Problem: loft command
Message 1 of 8
Hello
I need help about a product that i've create.
As you can see when i switch in realistic view the hollow is not smooth.
Here you can see the sketch of the hollow.
I create this product in 4 parts but that's not working perfectly.
Can you help me to solve my problem?
Thank you
Replies (7)
Message 2 of 8
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
Message 3 of 8
This was a difficult one, I tried using Patches but that was worse. It may be that you just need to define more rails.
Screencasts function isn't working, here's the link
https://autode.sk/3uVq4zA
Message 4 of 8
Thanks for help, i going to applied the tip
Message 5 of 8
Thanks for helping me, i give you the file.
Message 6 of 8
mango.freund
hello @Anonymous  her it is?
Message 7 of 8
Hey, thanks for your answer.
But is not realy that. As you can see on the last rectangular surface after the hollow there are a allowance.
The last surface need to be totally flat.
Message 8 of 8
mango.freund
hello @Anonymous  Of course I've seen that, but even when I make two individual areas and staple them together, this "ghostly" appears. - I did my best.
ps: more rails lead to even more bumps. greetings mango
