Message 1 of 9
- Mute
- Permalink
- Report
This probably has a simple fix, I just haven't found it. I'm trying to make a support for a touch screen display. The 4 upright supports are placed the required distance apart at the base but due to the elongation of the top due to the slice, it is too big for my use. I need the measurement at the top to be 0.3" x 0.3". After the slice it now measures 0.3" x 0.357". The odd extrusion in the middle was created from the construction plane down to the base based on a 0.3" x 0.3" rectangle. As you can see it is perpendicular to the construction plane and not the base. How can I get the extrusion to go down and perpendicular to the base?
