Timeline Issue
Timeline Issue
rcruss
Timeline Issue
rcruss
Hi all,
I wanted to roll back before the window cut and change the radius shown.  When I roll back to edit the Window Cut sketch, the original uncut version of the main body (Fin1 Body(1)), does not go back to its uncut form.  So after editing the sketch, if I try to roll forward again, I get an error saying that I need to reselect the geometry.  But I can't do that because the uncut body is not there.
Am I missing something?
As always, any help is greatly appreciated.
Russ.
jhackney1972
When the change you requested is so simple, I feel I must be missing the question.  Let me know if I missed something.  Model is attached.
John Hackney, Retired
rcruss
Thanks John.  I did get it to work by finding the sketch in the main timeline as you did.  I was trying to edit the timeline in the component itself (Solid Fuse and Fin Large:1).  Shouldn't that work as well?
jhackney1972
Basically the timelines are the same just when you activate a component, it makes the timeline show the features of that component only.  So yes, you can do it either way.  I just activated the component you referenced and made the change and it worked as well.
