Simple form creation
ibethel333
ibethel333
I am trying to larn simple form creation. I have started with a plane in form mode with 1 side x 1 side, then added an edge 0.5 to be in the centre. I then used edit form, selected an edge and using Alt1 extended so i have a 3 x 1 flet shape. I then did the same and extended the long edge out twice to create a form of 3 x 3 faces. I then selected one of the points and extended it upwards. When i go to smooth view the edges i created using the edit form tool stay shrp and do not flow as i thought they should. What am i doing wrong, i was following a simple design by 'learn everything about design' and i cannot get past this stage? Please can someone point me in the right direction?
The attached file shows a crease in the form after completing the above, where on the video, there is no crease line?
laughingcreek
Your not doing anything wrong.  there's been a bug associated with extrude where it will create a creased edge when you extrude boundary edges that run in cross directions (ie the corner of a square).  I think there are a few other situations where it will also, but can't remember ATM.  just uncrease them after.
ibethel333
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" /><meta name="Generator" content="Microsoft Word 15 (filtered medium)" />&lt;!--&lt;br&gt;/* Font Definitions */&lt;br&gt;@font-face&lt;br&gt; {font-family:"Cambria Math";&lt;br&gt; panose-1:2 4 5 3 5 4 6 3 2 4;}&lt;br&gt;@font-face&lt;br&gt; {font-family:Calibri;&lt;br&gt; panose-1:2 15 5 2 2 2 4 3 2 4;}&lt;br&gt;/* Style Definitions */&lt;br&gt;p.MsoNormal, li.MsoNormal, div.MsoNormal&lt;br&gt; {margin:0cm;&lt;br&gt; font-size:11.0pt;&lt;br&gt; font-family:"Calibri",sans-serif;}&lt;br&gt;.MsoChpDefault&lt;br&gt; {mso-style-type:export-only;}&lt;br&gt;@page WordSection1&lt;br&gt; {size:612.0pt 792.0pt;&lt;br&gt; margin:72.0pt 72.0pt 72.0pt 72.0pt;}&lt;br&gt;div.WordSection1&lt;br&gt; {page:WordSection1;}&lt;br&gt;&lt;br&gt;
jeff_strater
to illustrate @laughingcreek's recommendation, here is how to uncrease your model:
https://knowledge.autodesk.com/community/screencast/131cb907-92e2-4f58-b33e-0e09ac389e64
Jeff Strater
Engineering Director
ibethel333
Thanks Jeff
