Problem Creating Profiles from Sketch Curves
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I seem to be having this problem frequently however it is very incosistent when it appears...
I created a sketch by tracing a bitmap using the spline tool. One part of the sketch needs to be a straight line. I have never been able to create a straight line by using the spline tool so I terminated the continuous spline and used the line tool instead. I am continuing the line on the point where the spline leaves off. When I select my first line segment point I get the green box on the last point on the spline and a green box on the last line point on the starting spline point. My sketch curve should now be a complete profile but it is still open for some reason. I zoomed in to the max and there are no open points. As a result it is not selectable as a profie and cannot be extruded. There seems to be no way to close the curve to create a profile. I have ran into this exact same problem on several other sketchs.
See attached files.
