Press/Pull multiple surfaces simultaneously?
I need to add some relief to some sheetmetal component edges to allow for powder coating. The component is a simple extrusion (11-gauge steel) but is a fairly complex shape. Rather than have to select each side surface and perform a Press/Pull individually, I'd like to be able to select a group of side surfaces with the Window Selection tool. However, after I've selected all my desired side surfaces and apply Press/Pull, it deselects all but one surface and only applies the Press/Pull to that single surface. Is there any way I can force Fusion to apply the Press/Pull command to multiple surfaces simultaneously?
jeff_strater
Yeah, this is an unfortunate glitch in the Press/Pull workflow.  You can get there, but it's a big ugly.  You need to select the first face, start the Press/Pull command, make sure the type is set to "New Offset", then you can select more faces.
Jeff Strater
Engineering Director
Bummer. Thanks for the workaround though. Is this on the roadmap to be fixed?
jeff_strater
It is.   The internal item is FUS-27456.  I wouldn't expect it to be addressed soon, but I hope we do get to it one day...
Jeff Strater
