03:32 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I need to add some relief to some sheetmetal component edges to allow for powder coating. The component is a simple extrusion (11-gauge steel) but is a fairly complex shape. Rather than have to select each side surface and perform a Press/Pull individually, I'd like to be able to select a group of side surfaces with the Window Selection tool. However, after I've selected all my desired side surfaces and apply Press/Pull, it deselects all but one surface and only applies the Press/Pull to that single surface. Is there any way I can force Fusion to apply the Press/Pull command to multiple surfaces simultaneously?
